Original 67 Idler Arms - NCRS Discussion Boards
  • Kirk M.
    • June 30, 2006
    • 1036
    Is there a place to find original 67 idler arms? Thanks.
    Kirk
  • Alan D.
    • January 1, 2005
    • 2027
    Re: Original 67 Idler Arms
    Try America's Finest Corvettes, at one time you needed to call however.
      Kirk
      Kirk------
      If you mean NOS original arms, it will be difficult. You might find some from time-to-time on eBay. Beware of arms with the original forging number on the arm section (3779185) but a double off-set on the bracket section. Those are for 1963 pick-up trucks, not Corvettes. The Corvette arm has a single off-set on the bracket section.
      If you mean used original arms, they would probably be pretty easy to find but most probably wouldn't be any good and there's no way I know of to rebuild them.
      There is a good reproduction arm out there but it doesn't have the GM forging number on it.
      • Mike M.
        • May 31, 1974
        • 8365
        most repos have zerk fittings, whereas originals didn't have zerks.mike
        • Kirk M.
          • June 30, 2006
          • 1036
          What are zerk fittings? Got it grease fittings.
          Kirk
          • Kirk M.
            • June 30, 2006
            • 1036
            Kirk------
            So, rebuilding an original won't work. Oh heck. There does seem to be one made now with the numbers on it - check out 572009 at CC. What do you think?
            Just for my own edification, what exactly does an idler arm do?
            Kirk
              Kirk
              Kirk-----
              The CC part number is 572099. From what I can see of it, it looks like the original. I'd need to see one up close and personal to render a really informed opinion.
              The description says that it has the "casting number". I was not aware that any reproduction had that feature. If so, that would be a plus if the rest of it is right.
              • Tracy C.
                • July 31, 2003
                • 2739
                I used the repop from AFC. I've compared to an original and was satisified with the detail. I think a chassis judge would need to have his panties in a wad to deduct anything for it. It's nicely done and includes the casting number. You can see it installed in the pic below.
                • Kirk M.
                  • June 30, 2006
                  • 1036
                  Tracy,
                  This seems to be the same one now being sold by various dealers. Thanks.
                  Kirk
