Various Vacumm Tube - NCRS Discussion Boards
Various Vacumm Tube
  • Rey S.
    • April 1, 1995
    • 277
    Various Vacumm Tube
    I have several Vacumm tubes under the hood of my 1972 That are soiled and dingy. How can these be cleaned and with what ????
    Re: Various Vacumm Tube
    I've found that a little patience, a liberal spritz with WD-40, and gentle wipe with a clean shop towel gets the aged original vac hoses looking A-OK, without the need to 'shot gun' replace them with reproduction hoses that have a visually different set of stripe patterns...
    While you're at it, take a looksee visual inspection of the ends of each hose. Often, they're 'spread' from being in-place over a connecting nipple for eons AND you can find cases where the rubber is splitting in either a radial or transverse manner.
    Solve that by 'snipping' a bit of material off to get a 'fresh' portion of the rubber and you're probably good to go for years to come!
    • Michael D.
      • June 30, 1996
      • 536
      Soap and water will get the road gook off of them. I like Simple Green.
      • Ken C.
        • August 31, 2006
        • 120
        i've used gojo hand cleaner on hoses, spark plug wires, wires, etc. with good results. cleans them right up.
