Hood Support Question - NCRS Discussion Boards
  • Rick A.
    • July 31, 2002
    • 2147
    Friend of mine asked me the following and I had no answer:
    anybody know why??????
    Rick Aleshire
    2016 Ebony C7R Z06 "ROSA"
  • William L.
    • December 1, 1988
    • 944
    Re: Hood Support Question
    Don't know about any 5/8" hole? But the 5/16' hole in the hood support like the one in this picture with the "Do not remove before flight"
    pin in it.
    I may be wrong but I would think it was put there for safety reason's. Like maybe it wouldn't fall on this GREAT NCRS Judges head???
    Bill Lacy
    1998 Indy Pacecar
    • Jack C.
      • September 30, 1992
      • 1090
      That's my guess. You'll never know when a sudden gust of wind turns your hood into a sail and then slams shut.
      Jack Corso
      1972 Elkhart Green LT-1 Coupe 43,200 miles
      Top Flight 1994, 2018 & 2021
      • Stephen L.
        • May 31, 1984
        • 3148
        I've had the hood slam shut due to wind. I've even bumped the hood with my shoulder and it has fallen on me I"ve been using a bolt in that hole since!
        As far as that judge in the photo.... Appears to be Dale Crosby, so in this particuliar case the pin isn't required because he is an old hard headed friend..... might mess up his hair tho
        • Jack C.
          • 1090
          A clevis pin and a Jesus clip works perfect.
          Jack Corso
          • William L.
            • December 1, 1988
            • 944
            Stephen. You are correct on two counts, that is Dale and his hair never moved during the entire process of judging my car. He had no "deducts"
            Bill Lacy
            1998 Indy Pacecar
            • Rick A.
              • July 31, 2002
              • 2147
              ALL,
              yepper, use the pin myself, and so does my friend - but what was actually put there during the car going down the line????? had to be a reason, correct?
              Rick Aleshire
              • Jack C.
                • 1090
                This sounds like a question for John Hinckley.
                Jack Corso
                  I honestly don't recall, but I'm sure the plant used a pin or simple tool in that hole while the hood was open; floor chain conveyors (Hard Trim Line) and flat-top conveyors (Final Line and Final Trim Line) jerk or surge occasionally, and that could cause a Corvette hood to drop, posing a safety hazard. They used wooden sticks in the Paint Shop (before the hood support was installed).
                  I use the same thing shown in Bill's photo on my car when I'm working on it or showing it to avoid messing up my hair .
