I'm planning work on a L71 '67, performing a total brake overhaul using rebuilt o-ring calipers, new PB MC, rotors, hoses, etc. I will also be upgrading to the power brake system. I've worked on 67 PB systems but never installed a upgrade from scratch.
I've gone through the AIM and see I need some additional brackets for the booster, etc. This is my parts list for the project......Zip is my supplier.
DB647 Overhaul Kit
DB600 Booster
DB26 Booster Plate w/rivets
DB616 Booster Pedal Actuator Bracket
DB615 Booster Bolts
DB624 Booster Hose Kit
M2375 Booster Manifold Fitting
WS432 PB Pedal Manual Trans
Is there anything I may have missed? Any advice would be appreciated.
I am also confused about the Master Cylinder. I've read in Nolands book and the AIM, and searches here, that the MC is the same for both PB and Standard brakes, yet I see suppliers have 2 versions for the MC. What may be different about the 2 MC's....smaller bore size on the Power MC?
Rich
DB647 Overhaul Kit
DB600 Booster
DB615 Booster Bolts
Rich
