Aircraft Rivet Gun Help
- Top
Re: Aircraft Rivet Gun Help
aren't most of the rivets on Corvettes steel? I am thinking of the ones holding reinforcements to the body as well as on the A arms. Where does one buy these steel (iron?) rivets?
Mike
- Top
I took everyone's advice and purchased an aircraft rivet gun and tools off ebay (Figs 1-3). Just want to get it straight before I use it. I have also attached a pic of the body rivets (Fig 4). So,
1. I put the rivet through the hole with the large flat surface in the wheel well and the stem protruding through the hole and "J" clamp in the front clip area.
2. I place the gun in the wheel well with one of the large circular flat head "hammers" on the large flat surface of rivet.
3. I place the bucking bar (large flat bar in middle top of pic) on the stem in the front clip area.
4. Push on the gun so the large flat head of the rivet is flush with the body panel, hold the bucking bar pressed against the stem and pull the trigger.
Is that correct?
One final question, in Figure 1 there is a dial around the trigger. What does that adjust, the hammer strength? Thanks.
Kirk
Joe- Top
http://www.vansairforce.net/articles...OnRiveting.htm
tc- Top
- Top
