I'm having an intermittant problem I believe is related to the TI. Box, grounds and coil are ok.
I have checked the pickup coil and usually reads 670 ohms. I had it jump around a bit moving wires but it could have been a poor meter connection. My question is when you move the rotor, the ohms jump all over the place but go back to about 670 when I stop moving it. Is this normal or a symtom of a problem?
Thanks for any help.
I now understand that moving the rotor will cause the ohms to jump around.
