Re: Alternator Alignment 1963 327/250HP
Stu,
My early 1970 LT1, with no PS, came from the factory with a captive belt in the innermost (closest to the engine) groove. That is the way they did it for just the reasons Jim L cites.
Jim T -- the water pump hub on my 1970 has studs. It is a royal PITA to get the water pump pulley on and then install those studs. If I had a lift in the garage I would use Joe's suggestion. The good news is that the belts don't have to be changed too often any more.
Stu,
