I have a '67 350 HP Corvette with a proper replacement 4160 Holley. I have had an over rich problem with this carb since I had the engine rebuilt. I took it off and bought a rebuild kit. I made sure everthing was squeaky clean, and even lapped the mating surfaces on a surface plate to make sure they were all dead flat. Yesterday, I started to re-assemble it. When I got to putting the accelerator pump "squirter" in, I refered to the instruction sheet, and it shows that in the hole where the screw goes in that holds it on are 3 pieces. First into the hole it says there is a ball, next goes a "ballweight, and then goes a small needle. After that, the "squirter" goes in, held by a screw. Well, I looked in the tray of small parts I had saved, and found the needle, but no ball or "ballweight". I remember disassembling the card, and remember the needle, but have no recollection on anything else. Either I took them out and lost them, which is highly unlikely since I was very careful taking the carb apart, or they were never there. I checked all of the Holley books I have, and one of them seemed to allude to the fact that the ball and "ballweight" were used only on the spreadbore replacement carbs.
Does anyone know if a standard 4160 has these parts in them from the factory? And if so, could their missing have anything to do with the over rich condition I was having?
The "trick kit" I bought has a replacement ball, but nothing I could even place as a "ballweight". The instructions also say that, because of the many different model carbs, that there are extra parts in the kit.
Thanks in advance for any help you can give me.
