What does a stamp of 433 on a clock mean?
Clock Date Stamp
Re: Clock Date Stamp
Welcome to the NCRS board Paul !!
You mean a Saginaw casting clock ??
Here's how to read one.
On some Saginaw blocks, intakes and exhausts a "clock" was cast into the block. The clock is a circle of 10 dots, one dot for each hour of a shift (usually 10 hour shifts). An arrow points to the beginning of the shift an another dot outside the circle indicates what time of day the cast part was made.
I have lso read the screw in the center indicated the shift. A flat head screw was first shift and a round head was second.Tom Hendricks
Proud Member NCRS #23758
NCM Founding Member # 1143
Specialist for 27 years at BUDS Chevrolet.- Top
Wow, I was way out in left field on this one. I thought you were talking about casting clocks. Sorry.
Tom Hendricks
On the back of the clock in my late '65 (S-body trim tag dated 30 July), the ink stamp is "205". I always thought it was a Julian-dating system, as this translates to July 24th.- Top
Maybe they're experimental digital clocks accidentally installed facing the wrong way.- Top
The clock from the '67 I'm restoring was ink-stamped "210 6", which I understood to mean the 210th day of 1966 (car has a Jan. 11, 1967 build date). For a 1963 clock, Dobbins' Fact Book shows the ink-stamp date format as "Nov. 62" in his example on p. 317.
I don't know how "433" should be interpreted.- Top
