Transmission mount assembly - NCRS Discussion Boards
  • David H.
    • November 11, 2009
    • 777
    Does anyone have a good diagram drawing of how the 4 speed transmisson mount assembly goes together? Including the spacers for the '62 application.
  • David H.
    • November 11, 2009
    • 777
    Re: Transmission mount assembly
    OK, I'll assume that there is not a good exploded view diagram of this so here is what I got from the one in the Adam's book.
    Anyone want to comment on how I put it together is welcome to critic my assembly.
    • Dan D.
      • November 5, 2008
      • 1323
      It looks just like the one I just did. Mine is 57, but has a 62 engine and T10, so I used the shims too. Without the shims there is zero clearance between the top of the shifter frame and the bottom of the fiberglass tunnel. I think you are golden. Make sure you install the shifter before you do body drop. If you don't the shifter mounting bolts are a bear to install. - Dan-
