Greetings,
While not my first post I am rather new to the forum. My question relates to 1966 small blocks, but may be relevant to other C2s also.
I recently purchased a reproduction thermostat housing no. 3827369 from CC--although the source is probably irrevelant as it is a GM licensed item. My question is that there appears to be a lack of clearance between the top of the long screw (on the side of the housing closest to the hose)--ok bolt, but screw is a more proper term--and the underside of the air cleaner (the base).
Could someone with an original 3827369 measure the height of this housing from the intake to the top of the boss where the long screw attaches? My reproduction measures 2 5/16" in height to the top of the boss--but from the intake to the bottom of the air cleaner base is only 2 5/16" or maybe 2 11/32", which is not going to provide room for the head of the screw. I believe I have an original air cleaner base and the carb is a List 3367 (correct for '66 small blocks) and the intake is the original--date code and all. The screw head is positioned right beneath the edge of the air cleaner base and is a definite interference with the base
If original 3827369 housings measures 2 5/16" I must not have a GM air cleaner base. I suppose this boss could or should have been faced lower to provide the needed clearance. Help, please. Thanks.
Bill
Bill
(all at once).
And the '660 housing is aluminum, not iron. Right? Mystery solved.
