C1 engine casting number - NCRS Discussion Boards
  • Richard P.
    • May 31, 2002
    • 190
    I have a block with engine casting number 3756519 that is barely readable because of slag cast in and around the digits. I have probed it with a punch to see if it has been altered with some material other than metal, but it seems to truly be just a casting flaw. The date casting (K258) is clear and it has the pipe threaded hole above the timing chain indicating a flint block. The stamp pad says F120ID. My question is: has anyone else come across a block with this slag in the casting numbers?
  • John T.
    NCRS Financial Officer
    • January 1, 1983
    • 290
    Re: C1 engine casting number
    Short answer is yes. I have seen several and I have an 870 block with such slag.
    Hope this helps.
    John
    • Richard P.
      • May 31, 2002
      • 190
      Thanks John. Do you think this would be detrimental in judging or in the value of the block in selling it?
