I want to do an initial judging spring 2011.Iwant instal frt & rr oe shocks and springs,should I soda blast under carriage,respray undercoat etc or just install new suspension parts and leave undercarriage as is? Which option is best for judging and still hold onto "survivor" designation
1967 vette 327-300hp survivor car
Tags: None
Re: 1967 vette 327-300hp survivor car
Tony -I want to do an initial judging spring 2011.Iwant instal frt & rr oe shocks and springs,should I soda blast under carriage,respray undercoat etc or just install new suspension parts and leave undercarriage as is? Which option is best for judging and still hold onto "survivor" designation
Are you saying the car has a Bloomington Gold "Survivor" award, or that it just seems mostly original? What does it have for shocks and springs that needs replacement?- Top
John,
No - car has never been judged - I bought car from Pro Team Vette back in'95. I would like to know if it would be better to just leave undercarriage as is before my initial judging in spring 11. Engine,trans and glove box numbers all match
Thanks so much for replying- Top
Always have a car evaluated/judged before 'restoring' any detail of it. Cleaning is one thing, bead blasting is another. You mention replacing springs, shocks etc-, that works against the unrestored present status of the car.
It can only be original once............- Top
Anthony - There's no problem getting advice and I think you have received some good advice. If it's a survivor and original (it's only original once), it not only needs to be original but things need to be or appear to be 40 plus years old. If your goal is "survivor," routine maintenance is one thing but take care that you don't start doing "major" restoration. Pete- Top
