67 427/400 A/C Belts - NCRS Discussion Boards
  • Stephen G.
    • January 1, 2002
    • 303
    Quanta says that all the belts for these cars are 3/8" with the exception of the A/C. All of the belts on my car are 15/32. None are original. With the deep groove pulleys installed (all I believe to be correct & original) 3/8 belts will not work.
    I searched the discussions but can't seem to find anything definitive.
    Steve Gansky
    Newtown, (Bucks County) PA
    Re: 67 427/400 A/C Belts
    Stephen-----
    GM says the same thing as Quanta. All the belts except the A/C belt were supposed to be 3/8" belts. The A/C compressor belt was 15/32". As a matter of fact, most Corvette belt applications in the C2-early C3 period were 3/8". After about 1973 these changed to 7/16" belts and 7/16" belts were then also specified for SERVICE for most earlier applications, too.
    • Stephen G.
      • January 1, 2002
      • 303
      Thanks Joe. I guess I'm just going to have to do my own thing because the car just won't run with 3/8" belts.
      Steve Gansky
        Stephen-----
        You might have a hard time finding narrower belts. These days, I think 3/8" is about the narrowest belt generally available.
        I do not understand why the 3/8 belts won't work for you. I just installed a set of 3/8 belts on a big block that has pretty much the same pullies you have. In fact, I've also installed 7/16" belts on both big block and small block pullies with no problem, at all. So, I just cannot understand why you are having problems.
        • Stephen G.
          • January 1, 2002
          • 303
          I think you misunderstood me. The 3/8" belts bottom out on the pulley and don't run on the sides. They are too narrow. With 3/8" belts and a 15/32 AC belt the AC compressor stalls and actually slips the water pump belt.
          When I got the car it had all 15/32 belts. The alternator & AC were Gates and the water pump was a service replacement GM. They ran fine. When I put in a new radiator I thought I would get the Quanta's and try and get the car more correct.
          Steve Gansky
            Stephen------
            I have NOS examples of just about every Corvette big block pulley ever made as well as original NOS GM belts from the 60's, 7/16" GM belts from the 70's and 80's, and modern-day 3/8" belts. When I get a chance, I'm going to have to go out and try these belts in the various pullies and see "what gives" here.
            • Stephen G.
              • January 1, 2002
              • 303
              That would be great. I'll get you my pulley part number when I get back to the garage in the AM..
              Steve Gansky
              • Stephen G.
                • January 1, 2002
                • 303
                Joe
                My pulley is a 3889372
                Steve Gansky
