Car: 1967 coupe, L79 engine.
The current "replacement" 1967 fuel pumps are missing the "AC", and if I understand correctly, AC Delco no longer makes them, even if they're in an AC Delco box.
The older NOS service replacement fuel pumps WITH "AC" are 40503 units, not the correct 40433. The NOS 40503 with the "AC" logo are still around, but there is no way to tell whether the internal parts are dry-rotted, and even if not, it seems unlikely to hold up long to modern gasoline formulations.
Several vendors now offer rebuilt "correct" 1967 fuel pumps (looks like an original 40433 top portion crimped to a modern lower section). This would seem to be an excellent solution, except for concerns about the safety of re-crimped fuel pumps that were never designed to be rebuilt.
The 1966 small block fuel pump is designed to be rebuilt, and there are kits available that use internal parts meant to withstand modern gasoline. If a 1966 small block fuel pump will work on a 1967 small block, it would not be correct, but it should be safe and reliable with known internal parts.
The gaskets appear to be the same, but the levers for '66 and '67 look different. Can it be made to work?
Or is the current non-A/C 40503-style fuel pump, made who-knows-where, the only "safe" option for a small block '67?
