I bought the RH hood support, bottom must fasten to top of radiator support so did that, when I lower hood, support comes down and rests on Gen. brace about 1 inch toward pass fender from top hole on Gen. that bolts to brace and hood is 4 inches from closing, I believe my pulleys are for later 58 but that is supposed to make a small bit of diff? seems Gen is supposed to rotate towards engine so the hood support will pass by the Generator. Is the fan belt the problem being to long? Thanks. Brad.
