63 /340 carb. date code - NCRS Discussion Boards
    • 6940
    When reading the date code on the 3461s carb what does the date CC3 eqaute to? I thought there should only be one c and the number after that?
  • Joel T.
    • April 30, 2005
    • 765
    Re: 63 /340 carb. date code
    I would double check with the judging guide.. but one of the "C's" is the month (March) the "3" is the year (1963) while the second "C" is revision if I am not mistaken...
    Again, check the judging guide or wait for another member to chime in.
    Joel
      • 6940
      Joe, Does this mean that its a replacement carburetor assy.? the factory correct would read C3.
      • Joel T.
        • April 30, 2005
        • 765
        Ed;
        No, what you have is a correct unit assuming your build date is March '63 or later. There are some threads on this topic in the archive... do a search on 3461S. The general view is that the first letter is the revision or version designation, the second letter the month followed by the year.
        My carb is a BA3.. second revision January 1963.. Your CC3 is a third revision, March 1963 unit.
        Joel
        • Stuart F.
          • August 31, 1996
          • 4676
          I believe with the AFB model change to the 3720S & 3721S designations, the revision was incorporated as a suffix to the model number, i.e. 3720SA or 3721SB, etc.
          Even I wasn't clear about the 3461S as it has been along time since I had mine on my 63, but it sounds like Joe has it nailed.
          Stu Fox
            • 6940
            Guys thanks for the responses, I could not seem to find anything in the JM or Nolands book.
            • Kenneth S.
              • July 31, 1981
              • 302
              I've been told the second letter was the week code. So CC3 would be March, 3rd week, 1963. The Judging Guide does not mention the second character.
              Ken
