Greetings,
I've searched the archives for oil pressure at idle for Corvette 327 engines. It is common to find concerns about LOW idle pressure, but my issue is the reverse. That is, at reasonable rpms (2000-3000) my 66 300 hp shows normal pressure of 35-40 psi, however at idle it "drops" to about 30-35 psi. Is this a sticky gauge which needs attention, or a partially plugged line, or..........something else? Idle rpm 500-650. I've never seen this before. Oh, when I switch off the engine the gauge immediately drops to zero as it should. Ideas please. And 15W-40 oil... the old CL-4, I believe it is. I'm not GREATLY concerned about this but it would be nice to know what the idle pressure actually is and more importantly what the cause is. Thanks again for all the help.
Bill
Bill
