January 1967 coupe (#07873), L79 with air conditioning.
The following is a list of clamps that were removed from the car:
1)
Type: Side-screw style, slotted band
2)
Stamped on the band: Size 10
3)
Stamped on the band: Size 12
4)
Stamped on the band: DIA 1-1/16 Size 10
5)
Stamped on the band: NO 24 1-1/16 to 2
6)
Stamped on the band: NO 10 9/16 to 1-3/8
7)
Stamped on the band: BREEZE Union N.J. M12 (was on the bottom pipe fitting of the expansion tank)
8)
Type: Solid band with square nut retainer, with separate screw & square nut
9) 1 x mini-Wittek tower clamp on evaporator box drain tube (not shown, slotted indented hex-head screw broke off at clamp, is it possible to remove this clamp without destroying it?)
Type: Tower (very small)
Stamped on the band: not sure, hard to read until I get it removed and cleaned.
10)
Type: Side-screw style, slotted band, with integral LOCATING arm
No Corbin clamps found anywhere?
Should the second clamp on the expansion tank be a duplicate Wittek solid band-clamp? Are there ANY Corbin-type clamps on an L79 with C60?
I will post what the 1967 JG says about the various clamps in the next post.
1)
2)
3)
4)
5)
6)
7)
8)
10)
