Reuse/swap lifters? - NCRS Discussion Boards
Reuse/swap lifters?
  • Mark H.
    • July 31, 1998
    • 384
    Reuse/swap lifters?
    I've got a set of hyd. lifters that have less than 500 miles on them. Any reason not to use them in the rebuild of another motor?
  • Michael M.
    • February 1, 1993
    • 603
    Re: Reuse/swap lifters?
    Mark, you did not say if you are using the same camshaft with the lifters that have 500 miles on them. It's always good to start with new lifters with a new camshaft.
    • Tracy C.
      • July 31, 2003
      • 2739
      500 miles isn't very many unless they were put on 1/4 mile at a time..
      • Clem Z.
        • January 1, 2006
        • 9427
        when i would dyno test different flat tappet cams as long as the bottom of the lifter was still convex and smooth i never changed the lifters.
        • Ray G.
          • May 31, 1986
          • 1187
          Hello Mark;
          We often reuse(d) extremely low hour lifters in our own engines, but not for customers engines.
          As long as the lifter lobe remained as designed, slightly higher across the lifter surface to spin the lifter, and the lifter bottom was as previously mentioned (not concave) we would use them again.
          Hope this info helps your decision.
          Ray
          I hope you dance
