rear differential gives it's all - NCRS Discussion Boards
  • Mike R.
    • August 30, 2009
    • 321
    Re: rear differential gives it's all
    Hi Gary. Curious, what is the difference between first and second generation main bearing caps (both functionally and visually)?
    THanks
    Hi guys,Brad & Bob.
    I'm not going to turn this into one of my tech threads as some may think I'm doing it for my own purposes. I will be glad to answer any questions you have if you contact me.
    I will make a couple of points here though. Sounds like someone was pointing you in the direction of a new loaded Eaton posi, not what I'd use in my vettes.
    1- I never use fiber clutches, I wouldn't use them in a go-cart let alone a vette. Look at my pictures of them on Digital corvettes and you'll see what I mean.
    2- I know Tom Watt and do the 12 bolts builds now as well as what I coined as a super 10 bolt a few years ago. You can find my thread on these jobs on DC as well
    3-I never build any Eaton posi for c2- c3 with springs or plates. I machine fit them to work without them and they work better with less wear and no hammering. I believe I'm the only one building them like this. Both Brad & Bobs diff's are setup like this.
    Looking at your picture I see it's an early diff with the 2nd design bearing caps and stock bolts, the case is probably wrecked,ARP bolts with washers. I use ARP as well only I do not use washers with them in the vette build. I went over this with ARP a few years ago and they do not recommend the washers. I never use stock cap bolts and fit every cap to my spec's or fit a steel cap.
    Anyway if I can help you with any questions just give me a call.
    • Gary R.
      • April 1, 1989
      • 1796
      There were 3 designs on the 63-79, that I'm aware of and I think I've rebuilt every year diff in this range.
      The 63-64 use a "flat" rough cast cap, then 65-70 used the ones shown, 71-79 were similar only have a cast in tab over the shim.
      Here is a 64
      Here is one of super 10 with a steel cap and the 65-70 cap on the RH
      Here is a 71-79, this particular one was so bad I was able to remove the springs with my fingers.
      • James G.
        • May 31, 1976
        • 1556
        #18
        "The toms that I'm thinking of is in idaho. tomsdifferentials.com It's been afew years since i've had work done there so I'll call first. It is a road race car."
        Tom moved from California about 5 yrears ago. He was "the Man" in the 60's thru late 90's. Built all the differentials for Guldstrand, Traco and other racers of Thunder Alley.
