There was a recent topic on this board that asked about oil change interval and "morphed" into a discussion about coolant change intervals. So, I'll start a new one here about coolant.
One of the problems with a coolant change is that to do the job right, one really needs to open the block drains. This can be a real PIA on many cars, new and old. They're either seized tight, require the removal of the knock sensors (LT1, LT4), or are just difficult to access.
Many years ago, I used to use a Prestone Flush-And-Fill kit. This kit requires the addition of a supplied "T" to one of the heater hoses. The "T" can be capped afterwards or the heater hose can just be replaced (coolant change time might not be a bad time to replace heater hose, anyway---it's cheap enough even if you use reproduction hose).
When I used to use this kit it worked great. After flushing the system, you simply let the radiator drain, close the drain cock, and add the correct amount of full strength coolant to get you to the % you want (I usually use 55-60%). Last, you top off with water. Done. It makes coolant change a very easy job.
These kits are still available, but I have not used one in awhile. Has anyone else here used one lately, especially on a later model car, Corvette or otherwise?
