In an earlier thread there was a question on the type of differential bearing caps used on the 63-79 iron diff's. I posted pictures of each type but the 63-64 were not too clean, here are some off a '63 diff I did. You can see they also had the cast in tabs but not the ribs in the cap. Also they used weaker hex heads.
Hope this helps clear up the types used.
