1962 u-joints - NCRS Discussion Boards
1962 u-joints
  • Jerry K.
    • December 1, 1981
    • 93
    1962 u-joints
    While inspecting the drive shaft I noticed grease spray under the floorpan at the u- joint location.These have been in for about 20K miles and they have grease zerks . I'm going to change them, my question is were there grease zerks or not? The ST-12 shows to grease them but whoever I ask has a differant theory.
  • John F.
    • March 23, 2008
    • 2395
    Re: 1962 u-joints
    The 61 Shop Manual says they are sealed at the factory. Recommend to disassemble, clean, and lubricate every 25,000 miles.
    John F
    • Jerry K.
      • December 1, 1981
      • 93
      Re: 1962 u-joints
      Thanks John,
      Your choice of corvette is outstanding!!!
      Jerry
      • Gene M.
        • April 1, 1985
        • 4232
        Re: 1962 u-joints
        Jerry,
        If you push too much grease into the joints they will "spray" to areas around on the body underside. Most of us only put on enough miles each year to have initial greasing last for almost ever.
        • Jerry K.
          • December 1, 1981
          • 93
          Re: 1962 u-joints
          Thank You Gene,
          Have you heard the old saying " a little's good, a lot's better". Well not in all cases.
          Thanks Fellas
