I have an original power window 1960 Corvette. I want to remove PW as an assembly. There is a factory notch in internal metal door support for motor/reg to come out. Does anyone have a photo of an assembled power window motor with reg installed?
I cannot see how many bolts hold the reg to motor. I can only see 2. With this internal metal reinforcement intact it looks to be about 3/4" inch too narrow to slide complete assembly out. I read somewhere I can remove reg first from motor, then motor. There must be a better way. Anyone?
Brainstorming:
What if I remove the 2 lower rivets which hold this metal reinforcement to bottom. Maybe with rivets removed the reinforcement will move outward away from motor possibly giving me more room. I'll have to look again if ithis action will give me enough room.
Or, modify/butcher/chop/bubba reinforcement to accommodate this removal.
After working on these old cars and how crude they are, it's tough to imagine how chevy produced hundreds in one day. I wouldn't be surprised if this power window option was installed with door skin off.
I have talked to other NCRS members who said they left this option alone in their top-flite restoration simply because of the difficulty of this job. I hope to crack this nut.
Thanks for reading.
DG
Brainstorming:
Thanks for reading.
DG
