Ok, see if this makes sense. This past spring I put two properly dated heads on my car. In the process, I removed the exhaust manifolds. I cleaned them thoroughly with steel wool and then coated them in WD-40. Since then, I have kept rust off them by wiping them with a rag covered in WD-40. I assumed this would keep rust off while maintaining a proper natural finish. The WD-40 just burns off once the manifolds are hot.
So, when I got the car judged this fall, I took a two point deduct on the exhaust manifolds because of finish. I told the judge there was absolutely no finish on the manifolds as I had steel wooled them down to metal. He said there absolutely was and maintained the 2 point deduct.
Is it possible that someone coated the manifolds before I steel wooled them and that I didn't remove the finish? Just doesn't seem possible to me because after I did it, it looked like bare metal.
Just puzzled.
Kirk
Just puzzled.
Kirk
