1969 Clutch Fan - NCRS Discussion Boards
1969 Clutch Fan
  • Stephen B.
    • April 1, 1988
    • 876
    1969 Clutch Fan
    I've noticed that clutch fans come in two different sizes. I have a Sweitzer Clutch dated 1969 with a hub too large to fit in the 5 blade fan from the era. Can anybody shed any light on the subject?
    Re: 1969 Clutch Fan
    Easy, this is a well known issue. The change happened in 1971.
    Cars built before that had a fan clutch with small hub with small bolt pattern while '71 and later cars used a big hub with wide bolt pattern. Fan clutch HAS to agree with both the water pump drive hub AND the geometry of the fan it's mounted to...
      Re: 1969 Clutch Fan
      Jack and Stephen------
      There were also fan clutches that used the large (3-1/4" bolt circle) bolt pattern for the fan attachment and the small (1-3/4" bolt circle) bolt pattern for the hub attachment. These were used on some late 60's Chevrolet vehicles, but never Corvettes.
      • Stephen B.
        • April 1, 1988
        • 876
        Re: 1969 Clutch Fan
        Thanks for the information.
        • Grahame M.
          • November 7, 2011
          • 224
          Re: 1969 Clutch Fan
          Thank you so much for the information.
          cheers
          Grahame
          69 427 Tri-Power 4 Speed
          Black on Black
