Headlight Motor mount question - NCRS Discussion Boards
  • Rob M.
    • April 30, 2003
    • 657
    Alright, moving ahead on my impromptu headlight motor/bucket project. Question:
    Does the rubber bushing that the motor bracket is bolted to have an integral washer?
    One side has a washer that looks a little like a small shock washer and the other doesn't have one at all. The screw/bolt is set inside the rubber and the bracket is obviously slightly loose. It doesn't call it out in the AIM and the usual venders don't sell one on it's own.
    thanks
    Rob
    '66 327/300 Regional Top Flt
    '08 6 speed coupe
  • Alan D.
    • January 1, 2005
    • 2027
    Re: Headlight Motor mount question
    First I assume you are talking about your C2. See section 12 of AIM, electrical. Now LI has a good picture in its section 04 with the parts you require.
    • William L.
      • December 1, 1988
      • 944
      Rob here's a couple of pictures of the correct mount with washer, bracket and bolt with captured star washer.
      Bill Lacy
      1998 Indy Pacecar
      • Rob M.
        • April 30, 2003
        • 657
        Bill,
        Thanks for posting the pictures, but they weren't there (photobucket image has been moved or deleted).
        It sounds as if there is a washer as a part of that bushing assembly - I will have to order one the next time I place an order with LIC. Seems odd that one would be missing - I wonder if it has been that way since new.
        Rob
        '08 6 speed coupe
        • William L.
          • December 1, 1988
          • 944
          Sorry let me try again.
          Bill Lacy
          1998 Indy Pacecar
