I am building a test jig for flowing fuel nozzels and need the size of the fuel spider lines and the compression fittings and the nuts that attach the nozzels to the lines. And, if anyone has a source for these small fittings and tees ,that would really help Jerry
Fuel injection 63-65 Plumbing question
Re: Fuel injection 63-65 Plumbing question
I am building a test jig for flowing fuel nozzels and need the size of the fuel spider lines and the compression fittings and the nuts that attach the nozzels to the lines. And, if anyone has a source for these small fittings and tees ,that would really help JerryDick Whittington- Top
Jerry,
I will measure the tube size on my 57 FI tomorrow.
Aircraft Spruce Co. is a good source for tubing also.
Thier smallest copper is 0.125" od with a 0.031 id.
They a good people to deal with.
www.aircraftspruce.com- Top
to be safe i would use stoddard solvent as it has close to the same density as race gas,.76/.78. at 60 degrees. back in 1957 we had a wooden fixture that held the FI unit and 8 graduated cylinders that lined up with each nozzle and we ran the pump with a drill to see if each graduated cylinder would get the same amount of CCs. i don't remember all the details but we had to apply vaccum to something.- Top
A light vacuum (connect a hose and suck on it) applied to the fitting on the main diaphragm cover is needed to raise/lower the linkage which controls the spill valve.
An ideal application of vacuum would be to have some method of controlling vacuum to the main diaphragm and be able to vary the vacuum. The vacuum signal to that diaphragm is VERY light-------------about like puffing on a cigarette. Although, I can't tell you how much to suck, because I DO NOT smoke!- Top
I need the tubing and compression fitting sizes to make a test setup for pump output and individual nozzel characteristics. I have figured out a way to make disks of any orifice size so i need to understand how many pounds of fuel per minute can be deliverd. Just having fun. Jerry- Top
