Hood Latch Question - NCRS Discussion Boards
Hood Latch Question
  • Barry J.
    • May 28, 2009
    • 61
    Hood Latch Question
    It appears that my hood latches have to much movement and I am looking to replace them while I am restoring my car. Any recommendations on who produces the correct replacement or if anyone repairs the originals?
  • Barry J.
    • May 28, 2009
    • 61
    Re: Hood Latch Question
    I meant hinges not latches.
    • Barry J.
      • May 28, 2009
      • 61
      Do the hinges get judged? This is the original marking on 1966 427/425 hinges and folks have told me that big block vibration wears the pin hole those resulting in a replacement hinge.......see photos attached....I don't know if anyone has ever noticed the marking locations on the right and left hinges....
      • Stephen L.
        • May 31, 1984
        • 3148
        Hinges are subject to judging, how detailed I don't know, but they look at finish/paint. I'm not aware of hinge "wear" from hood vibration. The hinges are not tight new. Can you "shift/move" the hood in the closed position? If not then things are tight enough
        • Mike M.
          • May 31, 1974
          • 8365
          the c-2 judges will check out the hinges and make appropriate deductions if the mfgr logo is absent. in the pictrure in the first post, note the configuration of the spring washer. no one, to my knowledge, has the washers down correctly like that in the first post.mike
