The radio on my '57 has developed considerable static at low speeds which sounds like the signal is breaking up. I believe I've traced the source to the antenna as I can replicate the broken signal by just wiggling it. I've checked the cable fitting and it appears clean and tight. So, I'm thinking the antenna itself is either shorting out (is this possible?) or there is corrosion on the mast itself preventing a good connection. Does anyone have experience disassembling and cleaning these antennas who perhaps could share his or her advice and experience. Is this something that can be easily accomplished and are there pitfalls to avoid?
Gerry
Gerry
