As much as I hate to admit defeat, I am about to take my water pump and ditch it for a replacement.
I used a rebuild kit from CC and rebuilt it. I had no problems with the rebuild. It went better than expected actually. Everything went together without a hitch. (or so I thought)
I carefully installed the gasket to the back cover using plenty of sealer on it. (maybe too much?) Tightened it all down good and proceded to install the assembly on the block. I used gasket sealer to keep the four gaskets in place between the motor mount and the pump and the motor mount and the block.
I then filled the block with anti-freeze and checked for leaks. Nothing showed immediately. However, when I came back out the next day I had little green drips coming off the bottom of the assembly from what looked like the back cover gasket. It was hard to tell where it was actually coming from since you can't see behind it at all. I had to assume that the back cover gasket was leaking so I remove the assembly from the block and had to start over.
Well, I won't bore you all with the entire story here but let's just say that it has been back on and back off the engine three times so far and I can't seem to stop this leak. New gaskets all around each time has not helped. Tightening the back cover more has not helped. Filing the surfaces of the pump where they connect to the engine has not helped. Filing the surface where the back cover goes has not helped.
At this point I have to assume that the rebuild kit was not perfect and it is leaking somehow. Unfortunetly I discovered too late that the kit was made in China so the quality is probably not what it should be and the seal is leaking. I can't think of what else it could be. Has anyone used these rebuild kits from CC and had problems with them?
Although I am getting pretty good at cleaning things up and redoing gaskets etc, I am pretty fed up with it and just want to dumpster it and start with a new one.
Any suggestions on what I might be missing here would be much appreciated.
