BB Engine lift bracket bolt - NCRS Discussion Boards
  • Mike R.
    • August 30, 2009
    • 321
    What does the bolt that holds the rear engine lift bracket to the head look like (headmark? intregal washer or not? color?)? Thanks
  • Jack C.
    • September 30, 1992
    • 1090
    Re: BB Engine lift bracket bolt
    Mike. on my Jan built 68 400 hsp, the passanger side rear orange painted lift bracket and bolt. It doesn't have a washer, captive or flat. The head markings look like a CS within a circle with three lines equally spaced out at the circle traveling out to the boltheads edge. This was a tough one to get a look at.
    Jack Corso
    1972 Elkhart Green LT-1 Coupe 43,200 miles
    Top Flight 1994, 2018 & 2021
    • Mike R.
      • August 30, 2009
      • 321
      Thanks Jack for taking a look on Christmas eve!
      Mike
        • 15573
        I can tell you for color the bolt and lifting bracket will be orange on iron head Mark IV engines and natural (unpainted) on aluminum head engines.
        • Mike R.
          • August 30, 2009
          • 321
          So is the unpainted bolt on aluminium engines black or silver?
            • 15573
            Somehow I knew that would be the next question, and there is a reason I avoided addressing that question earlier.
            • Mike R.
              • August 30, 2009
              • 321
              It gets harder as the parts get rarer...
              I appreciate your help with the vacuum modulator line. Without your photo, I would not have known how to bend the line and make it look original. It woule be so much easier if I was only trying to make things perfect instead of trying to emulate 40yr old imperfection...
