Re: Edelbrock Electric Choke Issue
Paul,
On the piston type accelerator pumps like the Carter/Edelbrock, the piston height controls the volume of fuel. The squirter diameter controls the timing of the shot, (how fast it's delivered).
In Rogers situation, a bit more fuel earlier in the pump shot may cover this stumble without making a rich situation when warm.
There is a real art to carburetor tuning and when you get away from a stock set up (like Roger) it's important to understand how these carburetor circuits work and overlap each other.. Remember, timing first then carburetor.
Paul,
. With all the advice that I have gathered from you guys and everything I have read online, I feel confident that I will resolve this issue. I believe that leaning the carb by changing the metering rods was a good start. My car was getting very poor gas mileage (about 11 MPG); and that was with a decent amount of highway driving. Tomorrow, I will purchase an Edelbrock accelerator pump nozzle set (there are 3 different sizes). Obviously, I have one of the 3 on the carb now, so I hope that one of the other 2 will fix what's left of the hesitation/stumble. I understand that it is almost as easy as changing the metering rods & springs. If I am able to eliminate, or at least reduce, the stumble and perhaps improve the gas mileage, I will be very happy with my investment of $ 90.00 in parts (it's too bad I can't get paid for my time
). I will complete the project this weekend and will report back with the conclusion to my saga. Yes, I am being positive as failure is not an option!
. If I need to adjust the throttle plates, what is the procedure? Do I have to remove the top part of the carb, or the entire carb from the intake manifold? Is there an adjustment screw? Will my newly installed gaskets still be OK to use again? I thought that 850-900 RPM is the correct idle for a performance cam and a manual transmission. I can adjust the idle with the idle speed screw, but as I said, the passenger side idle A/F emulsion screw doesn't seem to affect the idle speed. The driver side emulsion screw works properly. Can one side not working be due to the throttle plates needing adjustment?
