Front sway bar/links attaching to lower control arm
Front Springs (portion visible between frame and lower control arm)
Lower control arm mounting bolts/anchor plates
Lower control arm bumper/bolts
Lower ball joint
Front spindles/steering arm
Upper control arm mounting studs/nuts
Upper ball joints
Front shock upper washers/nuts
Relay rod/tie rods/adjusting sleeves/clamps (this resulted in Asphalt overspray on oil pan and maybe harmonic balancer/pulley)
Steel brakelines/brass junction blocks/rubber hoses/clips
Motor mounts and ground straps (overspray on block)
Steering box/coupler/pitman arm (overspray on left exhaust manifold)
Fuel line/clamps/bolts (maybe overspray on fuel pump)
Battery box/attaching bolts
Front exhaust pipes (over spray exhaust manifolds/starter/rear transmission/shifter base)
Center exhaust hanger/ground straps
Emergency brake cables/equalizer
Driveshaft/yokes (overspray transmission tailshaft)
Pinion support/bolts
Rear shock/mounting bolts
Mufflers/rear exhaust pipes (overspray spare tire carrier/rear spring/bottom ends gas tank)
Other questions:
Upper control arm alignment shims not sure when installed and if coated. Also true of rear trailing arm shims.
Pages 73,176, 200, 241 of Noland Adams also shows nice bottom views of 63/64 chassis. Bottom surfaces show minimal coverage which probably makes sense due to fact chassis on assembly line cart was at about mid thigh level of workers and was probably difficult to spray under (p28.29). Bottom views also show what appears to be over spray on oil pans.
Jeff
