I recently replaced my rear cross over brake line (for cosmetic purposes only) in otherwise a perfectly operating and newer brake system.
My problem is I'm having no luck at all bleeding either one of the rear brake calibers.
I have repeatedly tried gravity bleeding, one man vac pump and the Mrs. working the pedal for the last couple of days with no luck at all ----- no fluid or even air bubbles visible!
I re-filled the rear section of the MC with fluid which emptied when I replaced the rear cross over line which I assume is normal, the front section is still full as it should be; however the fluid level in the back section has not reduced at all throughout my failed bleeding attempts described above.
At this point I'm not sure what to do ???? ----------- I'm leaning towards removing the rear brake line at the MC and at the junction of the rear cross over and blowing some compressed air through it to see if the line is clear?
Is it possible that the problem is in the MC?
Should I consider removing the MC and "bench bleeding" it? ------- I have never removed one of these before, but it seems straight
forward?
I would appreciate any ideas or recommendations.
Thank you in advance,
Ralph PS: this is a 1966 application with power brakes and DOT 5 silicone fluid.
forward?
