1967 SB fan shroud -can black paint be removed leaving correct unfinished fiberglass? - NCRS Discussion Boards
  • Scott S.
    • September 11, 2009
    • 1961
    I need to replace a small block 1967 fan shroud. It seems my options are either to collect the three individual black (charcoal colored) NOS fiberglass pieces, or locate an original fan shroud in good used condition, with mounting tabs intact. If I understand correctly, the 1966 and 1967 small-block fan shrouds are identical, except the 1966 shroud was painted black while the 1967 shroud was raw unfinished black fiberglass.
    So far, I am only finding examples that have been painted, which leads to a couple of questions.
    1) Assuming for the moment that any painted fan shroud is from 1966, was the fiberglass black under the black paint in 1966, or was the fiberglass gray under black paint?
    2) If I get a painted fan shroud, and I can confirm there is charcoal/black fiberglass under the paint (e.g., an original '67 that was painted at some point over the years), is there a way to strip the paint so that it would leave the shroud appearing natural and unfinished, as if it had never been painted?
    The picture below is an example of a fan shroud in what appears to be very nice condition, but painted black.
  • Keith G.
    • October 31, 2006
    • 316
    Re: 1967 SB fan shroud -can black paint be removed leaving correct unfinished fibergl
    I did it with plain old zipstrip and had no problems.
    • Rich P.
      • January 12, 2009
      • 1361
      lacquer thinner and scotch brite woks wonders.
      • William L.
        • December 1, 1988
        • 944
        That's the way I have always done it. I agree with Rich.
        Bill Lacy
        1998 Indy Pacecar
        • Gary B.
          • February 1, 1997
          • 6979
          '66 fan shroud
          Scott,
          For '66 the fiberglass color might be different for early vs. late cars, but my July build date '66 has the very dark charcoal under the black paint.
          Gary
          • Bill L.
            • February 1, 2004
            • 1403
            I did my 70 with lacquer thiner and scotchbrite pad and it came out perfect.
            Bill
            • Brian M.
              • February 1, 1997
              • 1837
              I used Berkebile B101 gum cutter, leaved beautiful bare glass behind.
              • Scott S.
                • 1961
                It seems a lot of these fan shrouds have been painted over the years, good to know they can be returned to their original condition. Thank you (everyone!) for the replies,
                Scott
                • Chris E.
                  • November 3, 2006
                  • 1322
                  Lacquer thinner and paper towel worked GREAT on mine.
                  Chris Enstrom
                  2011 Z06, red/red
                  • Joe R.
                    • July 31, 1976
                    • 4547
                    Recently, I purchased a large number of fiberglass pieces for the fan shroud. The early replacement pieces and the originals were black fiberglass but the later replacement pieces were gray. Those would definately have to be painted to present well in any Corvette.
                    Any original to the Corvette 66 or 67 should be black fiberglass. Replacement pieces to repair a shroud could be either black or gray.
                    Good luck on finding what your require. My pieces sold at Carlisle very quickly. Must have sold them too cheap.
                    JR
                    • Tom R.
                      • December 20, 2010
                      • 177
                      I've been following this and a couple other threads on this subject and am a little confused. My 63 FI car has the correct "humped" horn mount core support, no holes for A/C lines, and an all steel fan shroud with a stapled hard rubber piece at the bottom. All the fan shrouds I see in the various aftermarket catalogs are fiberglass, and I haven't seen one steel replacement offered.
                      I looked at my AIM and it makes reference to spot welding on the shroud at what appears to be an upper and lower joint. What is correct for my car, steel or fiberglass?
                      • Craig O.
                        • July 31, 1983
                        • 207
                        63-65 metal
                        • Tom R.
                          • December 20, 2010
                          • 177
                          Originally posted by Craig Olson (6815)
                          63-65 metal
                          OK, thanks.
