Cascade green paint is on the 56 and she is looking much better! Next steps are to install various components....all wiring, insulation under dash, cowl vent, gauges, etc. Basically everything as you can see from the attached pictures. I wanted to know if there is a better sequence than another to install some items. I know the windshield assembly should be one of the first items, but beyond that, it's anyones guess. I can kind of figure it out by trial and error, but I'd rather avoid the error part if you know what I mean. Since I didn't take it apart, I can't even go in reverse sequence.
Any basic help or advice on sequence would be greatly appreciated...
Thanks, Mark
Thanks, Mark
). Having the components in the engine compartment already installed will hopefully keep me from having to lean over the fenders to do this. Putting my car back together I know is going to be a learning process and of course there is always the issue of parts. There is always something you have over looked that is going to hold you up on getting things done. I think your car looks really good! I hope you will share pictures when you are finished. I wish you all the best on your restoration project. Brooks Glover (2141)
