'63 steering damper date/color survey - NCRS Discussion Boards
  • Alan D.
    • January 1, 2005
    • 2027
    Re: '63 steering damper date/color survey
    Have to disagree, for a good part of 64 the shocks were also black!
    • Ron B.
      Infrequent User
      • July 31, 1976
      • 20
      Alan:
      I am sure you are correct. I meant to say 63 was the last year that only black was used. We know that most changes were phased in.
      Ron
      • Timothy B.
        • April 30, 1983
        • 5177
        #18
        Jon,
        Instead of driving yourself crazy trying to find a date coded part that's probably wore out why not consider installing power steering if you drive the car.
        It's a nice project and not difficult to do at home in the garage. Combine this with steering box service, lube and adjustment and you will see a big difference in driving enjoyment.
        I installed the P/S on my 67 and it's made me so lazy when driving around corners I don't feel like downshifting anymore..
        • Joe R.
          • July 31, 1976
          • 4547
          #19
          Jon,
          To answer your question
          The steering shock was gray. Replacements were black until the 70's and they were gray again!
          63 250-300HP without PS had a steering shock!
          63 340-360HP did not have a steering shock! (This is for John D) Unless of course you have a 300HP pan and your vehicle is called the REPOMOBILE!
          JR
          • Jon R.
            • February 8, 2010
            • 163
            #20
            Timothy,
            I do drive the car and I also enjoy the non power steering (and brakes). Makes me think about driving! I like that.
            There are no problems with the steering as is, I just wanted to bring the car back to the original configuration.
            Jon
            • Jon R.
              • February 8, 2010
              • 163
              #21
              Joe,
              Thanks, I will make sure the one I finally install is grey!
              Jon
              • Michael F.
                • June 4, 2009
                • 291
                #22
                Originally posted by Timothy Barbieri (6542)
                Jon,
                Let's see? Replacement dampner $100. Power steering setup $1000. Why bother? Since he's happy with what he's got. I prefer mine manual anyhow.
                • Timothy B.
                  • April 30, 1983
                  • 5177
                  #23
                  Michael,
                  Anybody that pays $1,000 for a power steering set up is being steered in the wrong direction..
                  • Michael F.
                    • June 4, 2009
                    • 291
                    #24
                    Michael,
                    True, if you have access to a good batch of used parts. Many don't have the time or desire to hunt them down and restore them.
                    The following is CCentrals conversion w/pump. When all is said and done. If you pay someone to install, it will be right at or just over the $1000 mark.
