1956 DualQuad adjustments CARTER 2362A - NCRS Discussion Boards
  • James S.
    Infrequent User
    • March 1, 1984
    • 19
    Having difficulty with 1956 dual quad carb adjustments !!!! Specifically fast idle set and release ???? Because of difference in 1956 Carters Rear (2362A), most publications/picture show 1957 or later carbs. Looking for reference with simple step by step instruction to fix intermitent function. Thank in advance Jim S.
  • Stuart F.
    • August 31, 1996
    • 4676
    Re: 1956 DualQuad adjustments CARTER 2362A
    Jim;
    It's been many years since I worked on 56 dual quads, but I recall the set I had used air idle screws on each carb. Is that what you have?
    Hope someone more current can jump on and give you a hand.
    Stu Fox
