Blade battery disconnect problem - NCRS Discussion Boards
  • Richard L.
    • December 4, 2009
    • 166
    Went to install my new Wirth blade battery disconnect to gain bonus points for an upcoming meet. Easy to install, but then no power (yes, I moved the blade into the proper position). Took it off, battery cranked fine. Since there aren't alot of ways to install this baby, like one only, I must assume the disconnect is bad. Any ideas?
  • Richard C.
    • July 31, 2001
    • 144
    Re: Blade battery disconnect problem
    Richard these things are the BEST every cvt that comes in my shop gets one there are 2 phillips head screws on it make sure they are lock tighted just a drop, the blue stuff. you can call the shop @615-255-3939 i have never seen one bad. maby the cable is not tight enough?
    • Richard L.
      • December 4, 2009
      • 166
      Thanks Richard. It seemed like I had everything tightened up, but I will give it one more try.
