I am running into a small issue with the rebuild of my clutch and brake pedal assembly. I got new bushings from Paragon and have them installed but when putting the clutch pedal shaft back into the bushings it is running up against the shoulder on the shaft of the clutch pedal. (see the picture) It seems to be a good fit on the shaft until it gets to that point. I don't want to force it and destroy the bushing.
How much pressure (what size hammer!
) should I use to push the shaft into the bushing? Or is something amise here?
THanks
) should I use to push the shaft into the bushing? Or is something amise here? THanks
