All of my research has been fruitless......
On these two distinct 391 square port heads on separate listings on ebay right now, I see the area surrounding the exhaust crossover area is different between the two. The crossover is needed for the divorced choke operation correct? One has no crossover at all and no surrounding openings, the other has the crossover port, with open areas above and below it. These openings go nowhere, but surround the port(for cooling?). Why are these differences seen on different heads with the same casting number?
So.....on the one that has the openings, what is supposed to cover the upper opening on a 3x2 435hp? The aluminum manifold does not cover the upper openings on either side. Is it the intake gasket? The JG states the gasket should fit the profile of the intake, not the head. But if the gasket is cut to fit the intake, the upper opening is exposed.
The 1st pictured head(no x-over, no openings) is J 10 6, with no single hump. Full ebay link here.
The 2nd pictured head(with x-over & openings) is A 21 7 with single hump Full ebay link here.
Rich
Rich
I just noticed looking very closely that the intake gasket is still installed and covering the port.
