While performing the rear brake overhaul, I noticed the body mounts where dry rotted and brittle. The bolts seems to screw in from bottom-up. Is it more complicated than just unscrewing the bolts, sliding in the new rubbers and re-screwing the bolts back in place or will I need to access the inside of the body mount bracket for the replacements. Thanks
82 rear body mounts
Re: 82 rear body mounts
Isaac the body mount bolts screw into a captured nut. If your 82's body mount bolts will unscrew easily, you will have no extra problems changing out this rear rubber body mount. Recommend using grease on the bolt when you install it. Do not remember what the torque is on this body mount bolt.- Top
Hi Jim, The fix up looks simple but researching the problem I found it can go from a minor to a major fix up. Below is a website that can address the major if needed. I hope it helps. Thanks for the reply. http://www.corvette-restoration.com/..._repairs_5.htm- Top
Isaac I removed the body bolts on my 1970 when it was about 18-19 years old and had no problems. One think I noticed in the major repair website was the reuse of the rusty bracket that retains the captured bolt.Hi Jim, The fix up looks simple but researching the problem I found it can go from a minor to a major fix up. Below is a website that can address the major if needed. I hope it helps. Thanks for the reply. http://www.corvette-restoration.com/..._repairs_5.htm- Top
