Need Correct 64 Window Crank/Handle - NCRS Discussion Boards
  • Andrew P.
    • November 12, 2008
    • 84
    Howdy,
    Looking down into the spline hole of an original crank, the splines start where the cut-out (for the clip) ends. On the repros sold by ecklers and CC and most of ebay, there is a 2mm flat gap after the cut-out and before the splines start. Needless to say this won't work with an original 64-late regulator and my regulators are perfect.
    Does anyone know where I can get either a clean original or correct repro handle?
    Thanks for the help!
    Drew
  • James W.
    • December 1, 1990
    • 2640
    Re: Need Correct 64 Window Crank/Handle
    Drew,
    I'd try Doc Rebuild (203) 366-1332. In one of his more recent catalogs; he states that he has 1963-1964 NOS window cranks (p/n 1079732) for $39.50 and nice repro's (p/n1079741)for $19.50. You could also call Long Island Corvette Parts, Corvette Central or Pragon Reproductions. I've had good success ordering good reproduction parts from all of them.
    Best Regards,
    James West
    Omaha, NE.
    1964 convertible
    1965 coupe
    2008 ZO6
    • Andrew P.
      • November 12, 2008
      • 84
      Hi James,
      Nada at all these guys. Also trued AFC. Nada again. Other Ideas?
      Drew
      • Steven B.
        • June 30, 1982
        • 3976
        Originally posted by Andrew Palenscar (49695)
        Hi James,
        Drew
        Grossmueller's?
        Good Luck!
        Steve
        • James W.
          • December 1, 1990
          • 2640
          Hi James,
          Drew
          Drew,
          I was looking on EBay last night and found one used original 63/64 window crank. It may not be up to you standards, but the description did mention that it was complete and functional. Sorry but I did not write down the auction number, I'm sure there may be more over time if you can wait.
          James West
          • Sydney G.
            • February 1, 1994
            • 443
            Originally posted by James West (18379)
            Drew,
            James West
            I may be wrong but were not the '63 and '64 crank handles different in design??
            If I recall, the judging manual does not address this difference.
            Syd
