PVC hose routing - NCRS Discussion Boards
PVC hose routing
  • Karl K.
    • November 17, 2008
    • 92
    PVC hose routing
    On a 327 350 hp what is the correct routing of the pcv
    hose from the oil fill tube to the carb?
    I just recieved one with the correct GM labeling on it and
    remember seeing it wrapped around something in a photo,
    not a direct run to he carb.
    Karl
    Re: PVC hose routing
    Karl
    Karl -
    Photo below shows a correct '65 L-79.
    • Karl K.
      • November 17, 2008
      • 92
      Hi John,
      Thanks for the help.
      Karl
      • Mike G.
        • January 1, 1991
        • 418
        Looks like the car in the photo is missing the spring clamp at the oil fill tube.
        • William C.
          • July 15, 2009
          • 239
          Karl -
          John,
          In the picture the throttle return spring is through the rod. On my 67 L79 a cotter pin is in the rod and the spring is in the carb lever. I have seen this on many cars. Is this a safety issue. I lost a point in judging and was told it should be in the rod.
          Bill
            Originally posted by William Cilles (50610)
            John,
            Bill
            Bill -
            Cotter pins were never used in this application - the end of the spring goes through a hole in the rod, and the flange on the white nylon sleeve is always on the inboard side, toward the carburetor.
            • William C.
              • July 15, 2009
              • 239
              Bill -
              Thanks John..
