I just bought an oil pan off ebay for my 1960 restoration. It was advertised as part number 359937, which is a service replacement trap door pan for 57-62. I have looked at the Restorer article that Tom Dingman did and also an article from Loren Lundberg and by comparison the one I bought seems to be correct as the service replacement trap door oil pan. I attached a couple of photos.
It is of course used and has a number of dents and dings which I would like to repair. However, there are some dings that I think are original, e.g. creased in the sump edge that were created when the pan blank was pressed into the mold.
Do anyone have closeup pictures that you could send me? Particularly of around the outside of the drain hole and outside of the sump area from the different sides? email: donh45@yahoo.com
Also, how best to repair? I can hammer out some of the larger dents, but what filler should I use for finish repairs? Will Bondo like material be OK? Obviously I will only use filler on the outside, then sand, prime, and paint.
Don Harris
Don Harris
. There is an NOS trap door oil pan on Ebay that has been there for months and the fellow wants $1,995. The one I got has dents and dings, but all seem to be repairable.
