'88 coupe L98 auto.... - NCRS Discussion Boards
  • Jeff P.
    • July 23, 2010
    • 29
    Hello I am the proud owner of an 88 L98 all original coupe with 22,000 miles on the clock...I'm hoping to top-flight my car. My question albeit a bit broad...are there any inherent problems I should be on the lookout for to keep my car in good running condition? I've owned it for 1 yr.
    Thanks in advance for your advise...
    Jeff
  • Pete B.
    • February 22, 2007
    • 318
    Re: '88 coupe L98 auto....
    Jeff, the best thing you can do is drive the car and "use" the systems...i.e. a/c, cruise, windows, door locks, blinkers, flashers seats ect. These cars have a lot of things that need to be excercised, sitting with no use, things get sticky.
    Keep the gas fresh, either use a "stabil" type of product or drive the tank out and keep it full.
    Get a battery cut off switch and use it, the alternator is attached to a hot part of the engine, there is a "heat sink" directly bolted from it to the manifold, so it needs to just keep the car operating and not constantly recharge the battery.
    I have 2 C4's an 87 and an 89 both less than 20k miles. They are very reliable, you just have to remember you have a 20 plus year old car and it needs attention even with the low mileage
    best of luck!
    Pete Bergmann
    2005 - 2013 C6 National Teamleader
