Hi all,
Attached are two pics. I have seen the radiator caps with the blue and red on the top before and never paid much attention. When I got one on an old radiator I bought, I noticed the AC partly hidden beneath the red and blue cover, so I decided to take it off. It is just pressed on over the edges of the rivet in the middle.
The red and blue cover says the cap is a 13# RC-22. Beneath is the type of cap we are more used to seeing, but it says 15# RC-26! So, is the cap and RC-22 or an RC-26?
The addition of the red and blue cover seems to be a completely unnecessary manufacturing step since the cap info is already stamped on the main cap. I thought perhaps if they mislabeled a cap, they might use the cover to correct the error. But there are so many of these caps with the red and blue cover that AC's quality control would have to have been horrific.
So, what's the purpose of the cover and why two different part numbers?
Bob
Bob
. Can you post a photo of the other side of the cap for the spring and other components this would also help in identify it correctness.
Based on my experience, the AC radiator pressure caps with the red and blue cover pieces are as indicated on the red and blue cover pieces for the AC radiator pressure cap part number, therefore the red and blue cover piece designates the application and pressure. The red and blue cover piece was to be left in place because as you observed the information stamped on the top of the radiator pressure cap underneath the red and blue cover can be different. As far as I know, there was/is no instruction on the boxes that these radiator pressure caps came in that directed the user to remove the red and blue cover piece and then use the radiator pressure cap based on the information stamped on the top of the radiator pressure cap.
