I need a new voltage regulator for my 1966 327-300hp. Car was built on Dec. 14, 1965 I know I need a 1119515 regulator. When looking for a correct date, how far prior to my build date should I go? Thanks for any info Larry.....
1966 Voltage regulator
Re: 1966 Voltage regulator
The one on the car is not correct its an aftermarket unit, not a Delco. Thanks for the info, Larry.....- Top
Agree with Peter on timing, if your car was built late in the month, you will be looking for a VR with that same month-year date.
As far as covering and aftermarket, the part number and date code are stamped and show on the mounting flange...
With a slight amount of patience you can find the proper date code, these went on a lot of GM cars back then.- Top
Larry,
I have a used "5M" 1119515 Delco VR in need of a better cover but it seems to me that a "5L" dated VR would be more appropriate for your car.
DaveAttached Files- Top
